M1 not recognized in updater
  • M1 not recognized in updater
    Attempted to update the M1 firmware to 1.3 but the updater would not recognize the camera. Any idea what the problem might be?
    Re: M1 not recognized in updater
    Hi Phil, only thing I needed to do was connect USB cable and then select storage mode on camera. After selecting storage mode updater recognised camera.
    Gary
      Are you on the latest version of Viewer 3?
        Stephen - for E-M1 updates you don't use Viewer 3, there is a separate program called Olympus Digital Camera Updater.
        Phil - slight revision of Stephen's question - are you on the latest version of the updater? An older version may not recognise the E-M1. Mine is at 1.03, and it happily did the firmware update to version 1.1 on the E-M1. Haven't tried going to the latest (1.3) firmware yet, it might insist on updating the Updater before doing that.
        Link to download the Updater program: http://www.olympus.co.jp/en/support/...meraupdate.cfm
          I do. .
            You can update using Olympus Digital Camera Updater or Olympus Viewer 3.
            Stewart
            My Zenfolio Site
            My Portfolio Site
              Mine didn't recognise the camera at first last night but then I noticed that 'Storage' was highlighted on the camera lcd screen. I pressed OK and all was well.
                Ditto. It's not made entirely clear that you need to press "OK", but when you do, the camera is recognised.
                Margaret
                  Finally got the camera recognized, clicked on the correct update tabs and 40 minutes later the M1 was still updating. Knowing that something was wrong, I disconnected the camera and checked the firmware version. The firmware version would not display however the M1 still seems to function. I am concerned that some of the firmware did update and some did not. Has anyone else experienced such a situation? What to do next?
                    The update of the camera does not occur until all the data has been downloaded to the computer, then when the camera update start you get the symbols on the screen at the back of the camera.
                    The download to the computer is dependant on the server load and the line speed - it is a big variable - the camera update from the computer takes about 2 minutes.
                      The firmware update is is two parts, download and update then when all is done you get an OK on camera.
                      Some people have had problems with the download phase, retrying later, solves that problem.
                      There is then a second request checking you want to update.
                      If you switch of in second phase when no entry sign showing then I suspect you will have unpredictable problems.
                      Gary
                        beat me to it Derek.
                          Finally got it to work. Updated to v1.3. Had to do it on the MacBook instead of the Windows Vista Computer. Don't know why but everything seems to work better on the Mac. Thanks for the help guys!
                            Glad you got it sorted Phil. I still find it a very nerve-wracking process.
                            I was a bit puzzled about using Viewer 3 to update the camera, the Oly web page at http://www.olympus.co.jp/en/support/...tware/firm/e1/ says that you should use the updater program. So I tried it from Viewer 3, since I wanted to update the E-M1 anyway.
                            Mystery solved - Viewer 3 actually launches the updater program to do the update. So it looks as if all of us were right If you want, you can launch the updater directly which is how I have usually done it.
                            It will be interesting to see if I notice any improvement in focussing 4/3 lenses or the viewfinder refresh rate at rugby on Saturday.
                            Ciao ... John
                              John, went right out and tried it with a 4/3 lens (14-54 2.8-3.5 ver.I) and could not see any difference, although I am trying to convince myself that there was. Anyway, maybe the shutter bounce problems will not occur, although I have not noticed the associated problem.
                              Phil
