Wrotniak on the E-M1
  • Wrotniak on the E-M1
    Andrzej Wrotniak's review of the E-M1
    http://www.wrotniak.net/photo/m43/em1-look.html
    Stewart
    My Zenfolio Site
    My Portfolio Site
    Olympus: E-M1 Mk11 | PEN-F + ECG-4 | XZ-1 | Lumix: G9 | LX100
    Zuiko: 40-150 Pro + MC-14 | 12-100 Pro | 7-14 Pro | 17 | 45 | 60 | OM 135
    Leica: 100-400 | 12-60 Lumix: 12-32 Samyang: 7.5 fisheye
    Re: Wrotniak on the E-M1
    Takes a bit of reading but well worth the effort. An excellent read. I'd like to get a look at the set-up file he referred to. His setup for the E510 was really useful as a starting point and I'm sure the E-M1 version would quickly become a standard start for many.
      A good read. I'm just a bit puzzled over his explanation of AE bracketing. Unless I'm misreading, it's not how mine works. I can set AEB for, say, 5 exposures. The camera automatically selects motor-drive. I then simply hold my finger on the shutter until it stops firing.
      EDIT: Having re-read Wrotniak's section, and re-evaluated my scribbling, it seems we are both at cross-purposes. What I was referring to as AEB above is actually Olympus' HDR bracketing, from the top turret button. But actually doing Olympus' AEB (from the set-up menu), you have to set motor-drive manually. And then it does AEB without repeatedly pressing the shutter.
        Nice to see Andrzej back after many months of speculation about his whereabouts.
        Steve.
        See some of my pictures at: http://www.flickr.com/photos/tagbartok/
        https://picasaweb.google.com/tagbartok/
        This is to remind myself that I'm sitting indoors instead of out there taking photos!
          Steve.
          Pleased to see the chap about and on line again.
          Best Regards
          They're Watching You!
            Originally posted by StephenL View Post
            .....But actually doing Olympus' AEB (from the set-up menu), you have to set motor-drive manually. And then it does AEB without repeatedly pressing the shutter.
            indeed, but it will just keep shooting; it's not linked to the number of exposures set in the bracketing options...ie using sequential you can end up out of sequence this way than using the correct number of shutter presses.
            very much swings and roundabouts, with the ultimate user choice being based on the shooting circumstances.
            I agree with Andrzej that, on balance, it would be good to link the bracket size to the sequential sequence using bracketing in the same way as is already implemented in the HDR settings.
            E, Pen and OM-D bodies
            43 m43 and legacy glass
              As already said a good article, even owning the M1 since end of Sept I found it clarified a number of things.
                I don't think the E-M1 behaves differently in this regard than earlier E-system cameras. You could end up out of sequence with AE bracketing on the E-3 - it's just that the E-M1 (and E-M5) sequence rate is faster - so the chances of not releasing the shutter button at the appropriate moment have become much greater.
                  Wrotniak has now updated his site with his assessment of the Image Stabilization in the E-M1. See here.
                    This astonishing conclusion leapt out of the page at me:
                    "While the hard-tech market, driven by specs and marketing blurb, may be hard to convince, I still think that image stabilization in still photography may be a transitional technology, going soon the way of the dodo."
                    What do you make of it?
                      As I read it, I think that he means that improvements in useable high ISO settings and the resultant increase in shutter speeds will eventually make image stabilization redundant. I think the preceding sentence is relevant: 'Last but not least, remember that each EV in usable ISO settings replaces one EV in AF effectiveness. With at least two EV gained in ISO since the last E-series SLRs, we already experience an effect equivalent to 2 extra EV in image stabilization.'
                        Bodies: E3, E-P1
                        Lenses: 8mm, 14-42mm, 12-60mm, 50-200mm
                          Take a look also at John Foster's: http://www.biofos.com/index.html
                          He's written a very good review and a "How to Setup,Cconfigure and Customise Your Camera"
                          niels
                          Olympus OM-D E-M1, HLD-7, OM-D E-M5, HLD-6, E-3, HLD-4, E-400, ZD25/2.8, ZDED50/2.0, ZD11-22/2.8-3.5, ZD14-54/2.8-3.5, ZDED50-200/2.8-3.5, EC14, EX25, 2 x FL-50R, FL-36, Sigma 30/1.4, MMF-3, mZD12-50/3.5-6.3, mZD12/2.0, mZD45/1.8, mZD60/2.8MACRO, mZD75/1.8, mZD12-40/2.8PRO, mZD75-300/4.8-6.7II, Panasonic 1.7/20ASPH, Leica DG Summilux 1.4/25ASPH - Olympus OM-1 (35&100/2.8)
                            Photographers somehow managed to hand hold their cameras for decades before IS came along. It's just something else with the potential to go wrong for me. It would be nice if Olympus made a gimmick free body for photographers.
                            David M's Photoblog
                              some of us older photographers find IS helps overcome increasingly shaky hands though (and problems carting around extra weight in the form of even my nice carbon tripod) so I'm very happy that Olympus have been kind enough to make the EM series with it on board
                              Different strokes for different folks
