AF not as accurate
  • #31
    Re: AF not as accurate
    Ditto on the positive side. I have been using since December and for what I do the AF is a huge improvement in both speed and accuracy. The only issues I have experienced are around very low contrast subjects which is not surprising but even then it is much improved over the MK1.
    It should be said though that I do not do action/BIF so my comments should be taken in that context.
    Hec
    • #32
      Originally posted by Walti View Post
      I'm still trying to work out what I've done wrong - The camera seems fine and has been subjected to a factory reset, so I'll start again!
      Enthusiasm has taken a bit of a hit though!
      I think I need to switch to CF+TR to resolve the issues I think I've had - I'll give it a go and report back!
      Oh dear - that's not a great place to be! Let's see if we can collectively get you back on track!
      Personally, I have grave doubts over the use of tracking having had very little success with it in the past. Like a lot of fancy automation, it removes control from the user and unless it's 100% reliable it'll only likely make things worse to diagnose.
      IMHO whenever there is a problem, it's best to return to the simplest setup possible and then take it from there. How about this for an approach:
      - Start with single point S-AF on a static subject with a tripod. Sounds stupid, but it'll at least remove concerns around basic lens and camera calibration. Might be worth trying it with a few lenses too.
      - Move to hand-held. Tests shutter speed and IS issues.
      - Move to CAF, no-tracking and with a single AF point. Use first on a static subject. Maybe doesn't add much, but it gives C-AF a run. Keep to static subjects, but move aim from things near to far.
      - Keep on C-AF single point and play with the C-AF settings - AF Scanner and AF Lock settings (loose/tight). Keep to same static subjects and see how the settings change behaviour.
      - Bring in multi-point CAF. See how the camera chooses its selected focus point, again keeping to static subjects.
      - Switch to moving subjects and repeat the C-AF tests. Start with single point and something simple such as cars or bicycles, keeping the focus point(s) over the subject by camera movement. Test movement both in parallel plane to camera (subject not changing distance) and perpendicular (changing distance). Ensure that shutter speed is high enough.
      - Play around with different subjects and different movement patterns. Experiment with C-AF settings, esp CAF Lock.
      - Lastly, see if tracking helps at all. It should, if working properly, remove the need to keep the subject under a focus point.
      Depending on where problems begin, you'll have at least some handle on where to go looking for a fix.
      Hope this is useful and not teaching anyone to suck eggs!!
      • #33
        Paul,
        Nice to see it all written out neatly! Many thanks.
        I'm working through a similar set of tests and have found that I'm now getting better than the MKi - so that's a start - the factory reset does seem to have done something (that I can't find) which has improved things markedly, and I'm now getting reasonable performance across the board. (I ditched all my settings and started again! - to be sure it wasn't a stray setting).
        I've got onto the C-AF settings and looks like the tracking is sorting most of the issue out, however trying to photograph songbirds in a tree the focussing keeps bouncing between the original subject and the nearest branch! which is fine once you've realised it's going to do it (so you use C-AF selectively).
        It does look like some of my issues are grounded in the difference in the way C-AF operates across the two cameras and I need to change my work to match!
        I have also had a battery out to reset lock up and a "check lens" issue though today, so I'm beginning to think I've got a rogue camera!
        • #34
          Normal service has been resumed:
          I think that the camera must have been out of the box and played with by the dealer at some point! I've ended up doing TWO factory resets! and re-started plugging through all the menus to get somewhere near normality!
          I have also found that the C-AF definitely works differently (though that was the whole point so no real surprise) and I have had to adapt very slightly to it! Switching to C-AF+tr has solved some of the issues I was finding yesterday.
          I have found that if the subject is not in brilliant sunshine, the C-AF does wander a few mm - but understanding that allows for a work around!
          Anyway some straight out of the camera photos: ALL are E-M1 MKii, 300mm f4 plus MC1.4. ISO3200, 1/1000, f5.6
          • #35
            PS - I wouldn't have put ANY ISO3200 photos up for people to look at from the MKi - so there IS a difference!
            • #36
              Now you can move on to trying ProCapture Low with C-AF.
              • #37
                And a post-processed version of one of them!
                I think I'm a little happier now!
                • #38
                  I'm just relieved that I've gone from a place where I thought I'd made a massive mistake with the camera to actually thinking there is an improvement over the MKi - yesterday was VERY worrying!
                  PRO capture and high res are on the menu for investigation!
                  • #39
                    [img]
                    https://c1.staticflickr.com/3/2869/33438235422_7188014d44_b.jpg[/img]
                    Black Headed Gull on a mission by Mark Johnson, on Flickr
                    Pair of Woodies by Mark Johnson, on Flickr
                    Mr Robin by Mark Johnson, on Flickr
                    First day out with the new toy. Reasonably pleased with results........
                    More practice and study needed.....
                    • #40
                      Nice shots, you can certainly enjoy! I'm still passing through the learning curve of this camera the same way, after three birding sessions I can see the improvements in the photos. As the camera is the very same, it's clear where is the need for improvement...
                      _3181132_DxO by c12402, on Flickr
                      _3170402_DxO by c12402, on Flickr
                      • #41
                        Ok, I forgot that factory reset the day I collected the camera. I think I need to do that.
                        Those shots Walti, shows the AF working well.
                        I think it's that lens reset. I cannot remember if mine was still at default.
                        The settings were the same in the mk1. Only thing I keep getting on the mk2 is the lens keep refocusing. Unlike the mk1, the focus don't move as much.
                        I do agree it could be me error but I can't seem to find where that error is.
                        • #42
                          Wow, that robin shot is absolutely amazing, well done!!
                          • #43
                            In reality, that robin resulted a very good actor, just look another nice water effect from the same bird...
                            https://flic.kr/p/RQKXq6
                            • #44
                              Good to hear that you're resolving the issues you had Walti.
                              I'm sure you'll be delighted with the Mark II, it does perform well.
                              I'm still learning but have been happy with the results so far:
                              Red Kite by David Goodwin, on Flickr
                              Crested Tit by David Goodwin, on Flickr
                              Robin by David Goodwin, on Flickr
                              Chaffinch by David Goodwin, on Flickr
                              Coal Tit by David Goodwin, on Flickr
                              Turnstone by David Goodwin, on Flickr
                              I look forward to seeing more of your images.
                              • #45
                                Absolutely love the turnstone.
