What would you like to see from Olympus next?
  • #31
    Re: What would you like to see from Olympus next?
    I would like to see an external design published for the camera - this would enable one to know how the various functions are supposed to perform - specific examples would include the how the various focusing modes are designed to be used.
    I would also like see the cameras having the ability to export a text file showing the various menu settings. I would not expect the data to be be imported as the location and values ranges of the data could change as a result of firmware changes. The export could be either via the memory card or via Oly Studio or Master.
    • #32
      One other thing. A GPS receiver to add the location to the Exif data.
      My website
      • #33
        I'm still not convinced that 14-bit sampling is anything but a gimmick unless you have a very clean signal and that means a very large sensor or very large photosites. According to DxOMark, the E-3 has comparable colour sensitivity and tonal range with the Canon EOS-50D, which has the same pixel pitch as the E-3, as well as 14-bit sampling.
        You can over-sample (to 16 or 32 bits) from RAW in post processing anyway.
        got to disagree Ian. If we had 16 bit sampling and the ability to impose a D-log curve on the data we could gain great highlight and shadow preservation as we then map the data down to 8 bit for screen or print
        For those of us who like the tone-mapped HDR captured images, imagine being able to capture all 32 bits in one button press.
        Yes the down side we would have to live with is the larger raw files.
        also I would like an EVF (I have no real gripe with them) and an electronic shutter - silent and fast
        Oh and most important for us astophotographers - a way of taking the IR filter out of the light path
        chris
        shetland
        • #34
          To those who have said they would like to see additional gadgets, I put the question:
          Would you rather see those gadgets added, than the basic camera firepower improved by better performance in low available light?
          I see Oly tempted to go down the route of adding bells and whistles, while losing purchasers who want the best image quality. Those are the purchasers who set the trend and the tone - the pro photographers and the really good amateurs, whose photos people see and think: "now if I had that camera..."
          • #35
            Some gadgets I would use, IS for one and the pitch/roll for another, but the fancy jpeg processing I'll never use.
            A gadget-laden camera is always going to come second place to a camera with good solid reliable capabilities, I'd happily ditch many features to be able to go to ISO3200 with barely noticable noise.
            • #36
              I forgot.. I would love to have that aperture ring to work on my E-system. It would be very useful on all mode..PSAM. Why limit this to only Lumix and Leica bodies?
              • #37
                The only feature of the E-30 I'd like to see added to the replacement for the E-3 is the level gauges.
                A stripped down E-3 with the best sensor available would be my camera of choice. I never use flash so don't need the built in flash. I only ever use aperture priority or manual so don't need all the other exposure modes and I only shoot raw so I don't need the JPG options.
                Multi spot metering would be nice so I suppose what I'm looking for is a weatherproof, digital, auto-focussing OM4 in a E-3 style body.
                Edit. Another feature I'd like to see is ISO down to at least ISO 25 as sometimes ISO 100 is to fast and using ND filters with the 7-14 is impractical.
                Last edited by David M; 7th February 2009, 03:03 PM. Reason: To add the ISO comment
                David M's Photoblog
                • #38
                  I would gladly sacrifice bells and whistles for improved low light and noise performance. The pixel count doesn't really need increasing, especially at the expense of noise. A bigger screen would be very useful and wouldn't impinge on camera performance. Incorporated battery grip and GPS are not a necessity.
                  However, the improvements I mentioned above regarding physical layout of the controls are just cosmetic and would improve the ease of use of the camera. I see this as an area where Olympus could improve their products at no extra cost to the end price. Some of the E-3 reviews I read in magazines did knock the layout of the controls and Oly should pick up on this.
                  My website
                  • #39
                    I would like a radio control so I could shoot "tethered" without actually being tethered if you know what I mean.
                    sigpicDave
                    • #40
                      E1 style buttons that "click" a little when you push them and are a little larger.
                      All the best
                      Lots of cameras and lenses.
                      • #41
                        I'd like a camera with a rotating/tiltable rear screen, IS and decent resolution with low noise at higher ISO and in low light.
                        I used the E1 the other weekend (thanks to Thea), it was lovely but there's no point in me buying one because it doesn't have the features I really want. I did like being able to see the settings without having to squint into the viewfinder or look at the menu back of the camera, so that would be good too.
                        I know there are people who absolutely adore their E300 or E330, perhaps an upgrade would be a good idea.
                        Other features such as the art filters and scene settings might be fun, but I can't say I'd use them - I seem to be happiest with the Aperture Priority setting, and forget about everything else.
                        Prices are going to be a problem though, and not just for cameras and other photographic equipment. We have friends who have a shop, they've told us that wholesale prices are rocketing because of the poor Euro/Sterling exchange. Apparently their wholesalers/importers buy in Euros and then convert the prices to Sterling, I presume it's the same for most imported things.
                        - my pictures -
                        • #42
                          It sounds like you want an E3.
                          As for prices, I work in photographic retail and cost prices are going up across the board. Most companies are putting up their prices between 15 and 25%. If you are going to buy in the next few months it's worth doing so now, if you can, while shops still have stock at pre-increase prices.
                          Ian C.
                          • #43
                            "Multi spot metering would be nice so I suppose what I'm looking for is a weatherproof, digital, auto-focussing OM4 in a E-3 style body."
                            Here Here! - put this in a E-4xx body and produce a high grade 70mm F2 lens I would be happy!
                            Cheers, Steve.
                            visit my website www.photoark.co.uk
                            • #44
                              I'd like to see massive discount vouchers for loyal long-time users of Olympus for upgrades...
                              • #45
                                Ian C.
                                Why the heck are prices going up in these uncertain economic times? Do companies actually what us to buy their products???? Prices should be coming down!
