Battery box ?
  • Battery box ?
    I find I carry a spare couple of batteries around with me loose in my bag. I've been looking for a small battery box to hold one, or perhaps two, BLN-1 batteries for my E-M1/E-P5. I found a battery box on Amazon, but it's just too small for the BLN-1. Does anybody have a solution ?
    Be nice, do your best, don't fuss.
    Re: Battery box ?
    Maybe a bit big for your requirements, but I carry more batteries, particularly if away for the weekend; I use little neoprene zip up bags from Poundland.
    They are normally with the tech stuff, phone cases, cables, screen protectors etc.
    Colour coded, padded, and will fit 5 or 6 BLN-1s, a 9-18mm mFT, a 14/20mm etc.
    Best Regards
    They're Watching You!
      Re: Battery box ?
      I use an appropriate size plastic bag, one per battery. The main purpose is to prevent foreign objects shorting the terminals, and secondly to keep the battery clean.
        Re: Battery box ?
        Yes, when I'm carrying a single spare I keep it in a small ziplock clear plastic bag.
        For two or three I use some hard plastic cases with a snap-lock that originally held 4 CR123 lithium batteries and were sold by 7DayShop. Three BLN-1s fit exactly.
          Re: Battery box ?
          Hi
          Have a look at this thread:http://e-group.uk.net/forum/showthre...t=battery+case
          pault
            Re: Battery box ?
            Yes, thanks: that also shows the ones I use, but they seem not to be available now.
              Re: Battery box ?
              Hi, I posted a thread about boxes that I found for my BLN-1 batteries at http://e-group.uk.net/forum/showthre...ht=Battery+box
              Cheers
              If I'm out I'm JustSwanningAround
              or more often at www.facebook.com/JustSwanningAround
                Re: Battery box ?
                I use a small camera zip up case I found in our local discount store.
                  Re: Battery box ?
                  Thanks for all the info'. I've ordered a couple of the JJC boxes from Amazon, however I do like the look of Ross's zip case. I may get one of those as well [emoji4]
                    Re: Battery box ?
                    I use a Thinktank DSLR Battery Holder 4 bag - it holds 4 of the EM1 batteries
                    see them
                    https://www.thinktankphoto.com/colle...ttery-holder-4
